No distance a problem and unreserved support for his clients.
I couldn't get a dealer I trusted nearby and I made contact with Peter even although he is hundreds of miles away from me.
I'm compelled to write this little update as I was expecting to be sitting in audio nirvana this evening with a new Ekos SE/1 sadly no.
The upgrade is still happening and the deck is in readiness for some TLC.
The arm was changed today all set up and put in place for a listen and Oops not as engaging as I expected at all.
So the arm was removed all connections checked and tight " although I did notice an irregularity of the size of shrouds and colour sleeves on the tag wires.
Maybe cosmetic but at that price and my OCD they were not staying.
So Peter installed the tag wires that came with Krystal and reset everything and went for round two.
Something was much better more attack and speed and bass went very deep and more tuneful than before.
During listening Peter noticed that the system not playing had become " noisy " some noise is apparent on Phono inputs at very high volume not playing but when we looked at the volume it was only 50 I stream radio at a lower volume than than.
It's a constant whoosh and hiss but both channels at the same time even swopping inputs around didn't change anything the noise moved with the input.
Now we're scratching heads especially with Peter being so far away from me.
Peter came to the sofa called the shop and is shipping a new Radikal Urika Ekos SE and Krystal to eliminate the problem.
And another flight each way.
What dealer has that level of commitment and level of stock to support his Clients.
Problems are very upsetting but how can you not be gobsmacked with a support like that.
I've heard people sniping from time to time about Peter this and Peter that and how can he support such a wide customer base and the answer is simple he gets off his arse and makes it happen and hats off to him for it " a quiet few days will make the heart grow fonder.
So support your local or not so local dealer even when it goes pear shaped he won't hide.
Just in case of confusion Peter is Cymbiosis
